Smart Cleaner; how exactly it works?
Alessio_841
Hi Community,
If anyone has detailed info about, can tell here how exactly works Smart Cleaner on Xperia X series?
How is acts on the apps, memory and sorage to automatically optimize the system?
Which are the parameters it follow?
What is the frequency of automatic optimization?
Thank you!
Tags (3)
10 REPLIES 10
Christofer
Champion
Thank you for the kind words! Slightly_smiling_Face
