Sound soft after nougat
Suraj117
Ever since I installed the nougat 7.0 update my sound is soft. Before that it was good, but now it's soft. My volume is at 100% but still soft. It's really frustrating because most of the times I can't hear my ringtone. Any options on what to do?
10 REPLIES 10
Marlon5248
I've got the same problem! Anybody solution here?
PelDiPzs
The volume of stereo speakers, when i listen music or watch video, is very low!
XxXxXxX
Have you try to sweep or clean your two front stereo speakers with a tiny soft brush from outside only cause these speakers are really dust magnet but be careful on doing that and sweep to one direction only, that works for me try it and let me know if you got something new 👍.
RameshGJ
I dunno how people have found this issue the ringtone volume seems to be very low when i play the song in music app it is loud when i keep it as ringtone it is very very low..
profile.country.PH.title
MarlonUk1
as far as I know, playing music uses both speakers (stereo), while playing ringtones would only ring on one speaker, you can however try to have your device checked at your local service center Local support
naveenchichu_av
 Hello friends i have xperia x, iam taking about speaker volume while incoming call ringtone too low, but while playing on walkman mx player etc no problem nice volume getting, but only the incoming call ringtone too much low,  can anybdy fix this problem. Pls reply me androi 7.0, f5122, kernlvsion 3.10.84
MarlonUk1
sound is very subjective, I suggest to visit a service center near you to compare with another identical device Local support
Pamungkas08
I got same problem,  any body help,  so sadly
XxXxXxX
Are you sure that you hadn't switched on the increasing ring tone switch cause that might effects the volume of your device ring tone.
