What is the model of the USB cable supplied with the Xperia X
Johnny_Curry1
I've got a generic cable with mine alongside the UCH10 quick charger, which specific cable model should I buy?
Jonas
Master
Hi @Johnny_Curry,
According to the information that I have available the USB cable included together with the Xperia X is called "UCB16".
Do note that the box content may vary between markets so if you want to be 100% sure which cable that is included with the phone in your market/region, please get in contact with your Local support team.
In most cases there is also a small white label on the cable where you can read the name of the cable.
The name of the cable for that is included with the UCH10 Quick charger is "UCB11" and this cable is needed for the phone to be able to use the quick charge feature together with your UCH10.
I hope that helps! Slightly_smiling_Face
5 REPLIES 5
Uliwooly
@Johnny_Curry
If you are going to buy a Sony USB cable, any cable will work, assuming that it's not a 10year old cable Face_with_stuck-out_Tongue if you have a PS4 you can use the same cable to charge the DS4
Johnny_Curry1
I know, it is just that when I sell the phone on in the future I'd rather sell it with all the Sony accessories. I believe it is Sony EC803 though.
Jonas
Master
Hi @Johnny_Curry,
Johnny_Curry1
Hi
Thanks for clearing it up, normally I wouldn't be concerned about which cable to use etc. but because it is for a fast charger I'd rather have the correct cable model.
Jonas
Master
You're very welcome and I totally agree with you, giving away the wrong cable so you can't use your quick charger isn't optimal! Slightly_smiling_Face
Have a great day!
