X ghosting / lines in wake screen on startup
RockInRoller
RockInRoller
After disabling developer options in settings, Seems the problem has cleared. I am going to give this a day of use before making as solved
3 REPLIES 3
Emil
Enthusiast
Hi @RockInRoller,
I'm sorry to hear this. Slightly_frowning_Face
Could you provide a picture or a screenshot of this? It would be very helpful to determine if this is related to your devices hardware or software.
I would also recommend that you restart your device to safe mode to see if this behavior may be caused by one of your downloaded apps as these will be temporarily disabled in this mode.
You can also try to disable developer options to make sure it's not a setting in there causing this behavior. You can disable this menu if you go to: Settings > Developer options > Off. Note that if you can't find developer options under settings you do not have them enabled.
Let me know how it goes.
RockInRoller
Emil
Enthusiast
That's great to hear! :smileysmileythumbsup:
 Let me know if you experience this again or if there is anything else you're wondering about.
