Do anyone come across this?
My mobile is really slow and getting hot easily after updating to 7.1.1
Same here - I tried everything! I turned off Smart Cleaner, userd the companion software to fix it but nothing helps.
It's getting so bad I almost can't use my phone
Same here!
It seems that Sony didn't well test the 7.1.1 (41.2.A.7.8) with my F8132 model.
I have to reboot my phone to get it work for a while. However it will become slow and hot eventually and require another reboot soon.
Anyone has workarounds before Sony fix this problem?
Sony Sony!! You always the best, how you make me so sad.
Happening here also, is this issue worse when adaptive brightness is turned on?
Since the June update I have to restart phone every 3rd day - it slows down . It used to run easily over a week before. (F8131, 7.1.1, July security patch)
This issue is caused around few weeks. We didn't see Sony's feedback here.
Not trust Sony anymore. too bad. I am going to Amazon tell people. don't buy Sony.
Good idea. Making an Amazon account myself to give bad reviews. Already stopped 1 family member from buying Sony.
It's the same problem with my phone. It get hot, the camera stops working and it is very slow.
After a reboot, it work's for a short time, but then it's the same problem as before.
I sent it to Sony, but today it returned with the comment, that the phone is normally working.
This was fixed for me in 41.2.A.7.35... finally!
