When I record snap vids with a filter that adds a sound, the result is a screeching static sound on top of the intended audio. This is resolved in very low audio when recording.
Anyone had similar problem?I sent to service they said they wont guarantee that the phone will work with any third party apps..
TLDR
When ur recording a video and you have sounds coming out from your speakers the resulting video audio is crap and screechy
Edit I tested with SONY camera app with AR EFFECTS here is results. Which means the mic is broken
X compact
Xperia x
If you only experience this issue with other apps then the problem it's the third party app, this will have to be address by the app developer.
I will try now with AR effects that are preinstalled to see if the same audio distortion is present when recording vids
