Rapid battery drain since latest update
@6298751704027297
Besucher
Never had a problem with this phone...... Until the latest update. Now my battery runs out at a ridiculously rapid rate! I'm doing nothing different to what I've always done with usage/apps etc so it's got to be down to the recent update. I notice other people are having the same problem, does anybody know if Sony have acknowledged this problem and if there's a fix on the way?
5 ANTWORTEN 5
profile.country.US.title
Qatrium
@Rie1
Hello there, some people reported that switching off Bluetooth and GPS (while not in use) will improve battery life. Try that until a fix is released.
@6298751704027297
Besucher
Thanks, Bluetooth is never on anyway but I'll take your advice and turn off GPS when not in use until a solution is found.
halogenic_sky
Besucher
if prepared to try a factory reset, I'd suggest that - it's a stock answer, I know, but........
MeroMero99
Besucher
Same here for me it's the Bluetooth as long as it's on the idle drain is high i went down from 1 day and 16h of use to 9h and I'm not doing anything different still using the phone normally.
MustangXperia
Besucher
Yes i confirm that the battery rapidly drain
