SD Card not detected
callummac92
Nieuw
I have recently bought a Sandisk Ultra 512gb micro sd XC A1 memory card to replace an 8Gb i had in my XZ3.
I can read it from my laptop and even transfer data to it, but when inserted into the XZ3 it is not detected. I have tried everything in the means of formatting, repairing via Windows etc but it will not be picked up by the phone. I can insert the old 8gb and is detected no bother.
Any advice as to whether this new sd card is compatible or if i am missing something. The sd card is brand new and bought from amazon.
Thanks
1 ANTWOORD 1
profile.country.PH.title
MarlonUk1
hello @callummac92
there is a site the lists the specs of the memory card  compatible with your device.
https://www.memorycow.co.uk/mobile-phone/sony/xperia-series/sony-xperia-xz3-mobile-phone
does it list the memory card you bought?
