Wifi and bluetooth won't turn on
JChang97
Xperia Z2 (D6503)(Lollipop 5.0.2)(23.1.A.0.726)
Wifi and bluetooth won't turn on after I disable airplane mode after I woke up
I already tried rebooting, safe mode and factory reset but it still doesn't fix it
Any resolution?
26 REPLIES 26
profile.country.RO.title
_alexdon_
@Hampus can you take a look?
alexdon
Hampus
Champion
If Wi-Fi and/or Bluetooth does not turn on and you have performed a software repair via PC Companion, it's unfortunately not much more we can do. I suggest that you have your phone examined by a technician at an authorized service center. You can contact your local support team for information about nearest service center and/or how to proceed with this in the best possible way:
http://support.sonymobile.com/global-en/contactUs/
Dusyant_25
Hi everyone,
Just wanted to let you know that the problem was NOT resolved at all.
After 3 days, the same problem occured. I finally took the decision to back up my phone and do a factory reset. It still did not resolve the problem.
I then had it flashed and reboot. The problem occured the next day.
I am extremely disappointed with SONY.
This is very disgusting to pay so much for a Smartphone and you end up having those problems.
I use my Bluetooth everyday throuh my Nokia Bluetooth Kit in my car and Wifi everytime I am back home. Now both are USELESS!!!
Can anyone be some help on this.
Will the ugrade to Lollipop 5.1 solve the problem???
Thanks.
True_Renato
I'm with the same problem here. Sometimes the wi-fi starts to work then suddenly it turn off and i can't turn it on again. The same occur with the bluetooth.
I don't think it's a hardware problem because i've updated some apps with the wifi before the problem ocurred for the second time.
Is this a usual problem? I can still change my phone on the store for a new one.
True_Renato
Here's a screenshot:
I've used the Pc Companhion to reset the system twice.
JChang97
It was hardware problem, just send your phone to service center for warranty
Azrailmewt
Hello
I'm absolutely desparate now. D6503 and right now back to 5.1.1 Lollipop.
A year ago all of a sudden my WIFI and Bluetooth started to have a malfunction - without me doing anything! All of a sudden I couldn't turn on WIFI & Bluetooth.
I contacted Sony (a Company I learned to hate) and they did sent me my phone back because the phone was bend - which was not my doing, it just bend on it's own and don't ask me how that happened. They said the warranty was lost.
So no warranty and I fought a lot with Sony and yeah, forget it. They didn't even care to screw the phone back, didn't even sent me the screws, the phone came dismantled and I had to live with it.
Nonetheless the WIFI & Bluetooth issue WAS NOT SOLVED.
So because I did spent a **bleep** lot of money for that phone and God knows I'll never buy a Sony again because of Sony and this horrible experience, I kept it and just used mobile data. Two months later, all of a sudden, without me doing anything - the Wifi and Bluetooth WORKED, just out of the blue without any explanation. I mean like a miracle.
That was eight month ago. Though the Wifi worked, it sucked brutally and I had to put a new antenna in it and after that everything worked fine.
A week ago , after 5.1.1., I experienced something called "Sudden death". I was chatting on FB in the night and put the phone next to my bed and slept. After waking up, I wanted to check the time, and the phone was dead. Like absolutely dead. Nothing was helping at all. So I let it charge for 3-4 hours. Still dead, only red LED. After trying everything possible, I went to someone to fix it and I have no idea what he did, but he could turn it on and he worked two days on that thing to get it back to life and I had to change the battery.
So yesterday I was in my WIFI and had to use Bluetooth. Everything was working fine. On the train I turned WIFI off.
Today, back home from a visit, I turned my WIFI on - and it was scanning the area, and it didn't find anything. So I restarted my Xperia after restarting Routers etc. etc., and we are back at the beginning. The *ultimate super* WIFI is not turning on again.
So I thought, **bleep** perhaps this whole happened because of 5.1.1, so I downgraded, I rooted, I really did everything I could.
There are two things I noticed:
1. When I started in safe mode, I saw that my bluetooth seems to be crazy and turning itself on and off all the time. I couldn't stop it.
2. When I installed Cyanogen 12.1 and it started,in hope, it could solve my problem, it brought all the time this error: "bluetooth-share exited/quit" [in german: bluetooth-freigabe beendet] and it didn't stop popping up and that caused it to crash and it was rebooting and crashing rebooting etc. etc.
This is the same message but from someone else in the Internet:
Quote:
Build fingerprint: 'Sony/D6503/D6503:5.0.2/23.1.A.1.28/151083418:user/release-keys'
Revision: '0'
ABI: 'arm'
pid: 13943, tid: 13961, name: BluetoothAdapte >>> com.android.bluetooth <<<
signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0x0
r0 b5030dc8 r1 00000000 r2 aca3167c r3 aca42378
r4 aec28940 r5 000102e8 r6 b505212a r7 00000000
r8 12d655e0 r9 b482b800 sl 00000000 fp 12d944a0
ip b6dda1a9 sp ac8e29b8 lr ac9dd6c3 pc 00000000 cpsr 600e0010
backtrace:
#00 pc 00000000 <unknown>
#01 pc 000fa6c1 /system/lib/hw/bluetooth.default.so (vendor_ssrcleanup+12)
#02 pc 0003abfb /system/lib/hw/bluetooth.default.so (bte_ssr_cleanup+38)
#03 pc 00003cb3 /system/lib/libbluetooth_jni.so
#04 pc 000e2cd3 /data/dalvik-cache/arm/system@app@[email protected]@classes.dex
So, what could I do? Any ideas?
jhantu
Ihave problem Bluetooth and WiFi not working
gamal1
After last update lollipop the WiFi and Bluetooth not working
Toxic95
just today i got the same problem on my z3 and i only bought it 8 months ago and i tried everything listed here and in other sites but no use at all, looks like the only solution is to get it to a service center right?
