A77 and wireless flash
daharri8017
Hi all,
Wondering if anybody can help please?
I'm due to upgrade to A77 shortly and need to use wireless flash but not with the on-camera flash as the trigger.
Currently own a F42AM and know this won't work as a wireless on camera controller. However, if i bought a F58AM, will this work as an on camera flash and controller with my F42AM as a wireless? Also, if i bought another F42AM could i use F58AM on camera and 2x F42AM off camera wirelessly?
Thanks for any help!
David
1 REPLY 1
profile.country.de_DE.title
cmosse
yes this will work as you plan to; you can control the HVL-F42 with the F58 flash: You can also use the ratio flash function when using multiple HVL-F42 units as remote flashes.
Kind Regards
Michael
