cleaning a sony ax390
carol_anne
how do you clean a ax390, please !
1 REPLY 1
Mick2011
Hi carole_anne :slight_smile:
Do you mean an a390? I think the ax390 is an amplifier :wink:
If you mean the exterior of the camera, I use a microfibre cloth, similar to those supplied with spectacles. They're great at removing greasy fingerprints and if you keep them clean, are non-abrasive.
The interior, including mirror and sensor, is a different matter. A blower brush will often dislodge dust particles, but if there's anything that won't budge using this method you should get it cleaned professionally.
If you need any more info about sensor & mirror cleaning, just ask :cool:
Mick
