HELP ME TO FIND!
profile.country.sv_SE.title
yiumo93
HELP ME TO FIND!
my camera is sony alpha a 65...
i trying to find RESOLUTION of movie on my camera setting. i want to lower RESOLUTION like 720p but it is just 1080? help me how to find it
1 REPLY 1
blaireau_photo
Hello yiumo93 - Welcome to the Sony Forums :slight_smile:
I think that the settings you are looking for are described on pages 105-107 of the user manual which can be downloaded from here:
http://pdf.crse.com/manuals/4287948131.pdf
The menu to adjust this can be found by following: MENU button --> [Movie Symbol] 1 --> [File Format]. However, having looked at the options, it seems that you can only choose various settings that involve 1080 line resolution or a far lower quality 'Web' standard. You may however be able to reduce the movie quality to your desired resolution using third party software on a computer such as a video editor.
Thanks,
Simon
