NEX- 5 SHUTTER SOUND
sonynex
i have a new Nex-5 and am delighted however how can i turn off the quite loud shutter sound
Thalamus.
Champion
Hi Sonynex,
welcome to Questions & Answers..:smileyhappy:
Unfortunately you will not be able to change the volume of the shutter as this is an actual mechanical sound..
3 REPLIES 3
Thalamus.
Champion
Hi Sonynex,
sonynex
many thanks for that response - yes it was a bit cluncky to be an electronic sound, so that is that
a pity as i like to take relxed and natural shots and the clunck is a bit of a giveaway
thanks again
Using timelapse application, even even turned off in general menu, there is still on/off Silent Shooting ON in applicatiion setting-p5. This is great, WELL DONE SONY.
