NEX-6 and powermonkey-eXtreme?
profile.country.sv_SE.title
cyberbengt
Hi!
Waiting for my NEX-6 to arrive. I’m planning a longer boattrip in the Philippines, without any electricity - does anyone know if the powermonkey-eXtreme will work with a NEX-6??
blaireau_photo
Hello cyberbengt - Welcome to the Sony Forums :slight_smile:
The NEX-6 can charge over a regular USB connection and according to the manufacturer specification sheet for the Powermonkey Extreme .....
https://www.powertraveller.com/_code/download.php?f=VS_PTL_PM_Extreme_zcard_Op3_V2.pdf
..... there is a USB Out socket. Therefore, if you use the USB cable that is provided with the camera, you will be able to attach this to the USB Out socket and charge the camera (this will also avoid the need to experiment with the various connector tips that are available).
Thanks,
Simon
2 REPLIES 2
blaireau_photo
Thanks,
Simon
profile.country.de_DE.title
cmosse
Hi
although the solar charger is compatible please keep in mind that it can take several days for the included battery to be charged high enough. So I would suggest buying at least 1 or 2 genuine NP-FW50 batteris as an additional power backup.
Best Regards
Michael
