Nex5n power save mode
Dadendyer
Can anyone advise if the camera power save mode will stop the battery becoming flat if the power is accidentally left on? I have found that although the screen switches off and the camera appears to power down, the battery becomes hot and looses power. The shop are not sure if this is a fault.
blaireau_photo
Hello Dadendyer - Welcome to the Sony Forums :slight_smile:
I have answered your question on the other thread that you started here:
http://www.sony.co.uk/discussions/message/774594#774594
Thanks,
Simon
3 REPLIES 3
blaireau_photo
Thanks,
Simon
Dadendyer
Many thanks
Dadendyer
Many thanks
Regards
Dadendyer
