does the sony a65 have remote control facility?
Hi beboyle
Looking at the a65 compatible devices here http://www.sony.co.uk/support/en/product/SLT-A65/compatibility
(scroll down!) you can use both wired and wireless remotes, although there are some functional restrictions with the wireless controllers.
Mick
Mick,thanks a lot......
You're most welcome
