Hey everyone.
I'm a filmmaker in the uk and wondering if I could switch my European NEX-6 to a US one using the USA version of the NEX-6 v1.1 update?
60p and 24p are very important to me and those aren't available on the PAL version I have.
Thanks!
www.youtube.com/nitsanpictures
Hi Nitsan, welcome to the Sony Forums
You can't do this, as far as I'm aware. Like most manufacturers, Sony have different firmware releases for different regions and it's generally not recommended to attempt to mix 'n' match your updates. Certainly attempts I've heard of have not worked out, requiring at best a reversion to older firmware, at worst a 'bricked' camera.
Mick
Mick
Thanks Mick,
I guess it's worth asking sony and seeing if they'll give a definite answer.
is is definetly not possible to cross update the NEX-6 formware to switch the available video format settings (PAL/NTSC)
ok thanks. Well I've already emailed sony so i guess we'll see.
Would trying to do so brick the camera?
Best,
n
