Audio passthrough (DTS-HD MA), KD-65XF9005
profile.country.FI.title
KariFIN
Hello all,
I purchased a KD-65XF9005 (XF90/X900F) unit few days ago. I also have a Yamaha RV-373 amplifier that is connected to the TV via HDMI ARC connection. Originally only the Dolby Digital passthrough from TV to the amplifier worked but after updating the firmware to 6.6520 the DTS passthrough also started to work. However, still the DTS-HD MA passthrough is not working. I also found this when googling about the issue: https://github.com/CiNcH83/bravia_atv2/issues/57.
Have  anybody else seen this issue? Additionally, is there any info on the upcoming firmware updates and whether this issue will be fixed in them?
Thank you for any info!
Br,
Kari
12 REPLIES 12
zefeer
It's not a player... it's external hard drive connected via USB to the television....
What if i connect with optical cable?
rooobb
The same. Not enough bandwidth.  You should connect your hdd to a player connected directly to an hdmi input in your home teather.
profile.country.US.title
gkalliamvakos
I would like to check if there has been any progress on this point.
What is supposed to happen, as DTS HD cannot be passed via ARC, is to pass the DTS core successfully (which isn't happening).
