When I try to play video files from USB I keep getting a message ; file corrupt or unsupported
Can you help ?
Hi there
Its more than likely that the Bluray player does not support the codec that you are trying to play. As you havent provided a model number of your bluray player, I cant tell you which codecs your bluray player supports, however they are in the manual - so download the PDF manual from Sony Support website and it should be closer to the end of the PDF manual.
Cheers.
