How to insert sim
Asbid
How to insert sim
Plz tell me how to put in and put out sim in Xperia m2
Is that like sd card or sim jacket come out
11 REPLIES 11
Uliwooly
@Tilly2017
Did you checked the above suggestions? have you tested a different SIM card?
Misterfied
My XperiaM4 Aqua is unresponsive, attempts to turn it on result in a white screen with the Sony text logo. from that point on it does nothing. I attempted to remove the SIM card and MicroSD card , have re-inserted the SIM card with the same negative results. Is there a Do It Yourself fix ?
To complicate matters, the problem seems to be the result of my attempt to re-install the system as the Xperia Companion was not recognizing the phone. A system program download also failed, when I tried to use it to repair the phone's system which brought on the white screen problem. Ferom that point on, I am stymied and unable to get the adroid system up and running . Please advise?
