Call history/log is not showing up
ktick
I made a call from the call history (to a last called number) and then locked the screen from there. Then when I unlocked the screen, I am not seeing the call history atall !!! Its showing blank, I tried to restart and make calls, etc. but still the history shows empty. Anybody else faced this issue ? Any known workarounds ?
This is a big problem as call logs are very important feature for me as a basic phone itself. Please give your suggestions.
33 REPLIES 33
DrCaipi
I am having the same issues and dont know what to do. It can't be so complicated to show missed, dialed, received calls. All options are shown yet the phone shows only last call. frustrating
konsulten
I have also an empty caller log even if have missed a call or made a call. Where is the "hidden" option, I cant find out how to get the log working so need urgent help......
konsulten
hmm if it could be so simple Slightly_smiling_Face
profile.country.RO.title
_alexdon_
It should be if you tap the third sensitive button in call log.
alexdon
FSM15
I am having the same problem with my Z1 Compact. I have tried restarting my phone, replacing SIM card etc and I have definitely selected 'show call log' in settings but it is still empty and not showing anything. Are there any other solutions as all suggestions have so far failed.
_alexdon_
Settings-apps-all-phone,force stop and clear data.
alexdon
Raye
I have tried this and no joy I have a Sony compact Z1. and no call log has ever been there? It's relatively new I got it working Fri n I transfered all my numbers from my iPhone did this upset it? Please help it's very frustrating!!!
kin3d
I have the exact same problem with my Z1 compact. Empty call log, definitely have the 'show call log' option ticked. Restarted, took the SIM out and all that jazz. Eventually, I got a new SIM, did a factory reset, which solved the issue temporarily. Couple of hours later it went missing again! I can't be asked doing a full reset every time the phone log goes missing! Surely there must be a way to fix this? I'm tempted to get my old iPhone out Face_with_stuck-out_Tongue
Arpinacio
Hi there.
I was facing the same problem and found some kind of a solution.
I've installed a call log from Google Play (Call Log Monitor, one with a red icon) selected all the log (with the check boxes) and delete the log. On the Phone log it appears a message saying "Call log empty", tried to make a call and the call appeared on the log.
Problem solved, with a little effort.
I think that the problem is with the recover app from Sony, so... DON'T use it Grinning_Face
Hope this post can help you all.
cyew86
This works for me, thanks!
