I made a call from the call history (to a last called number) and then locked the screen from there. Then when I unlocked the screen, I am not seeing the call history atall !!! Its showing blank, I tried to restart and make calls, etc. but still the history shows empty. Anybody else faced this issue ? Any known workarounds ?
This is a big problem as call logs are very important feature for me as a basic phone itself. Please give your suggestions.
"I've installed a call log from Google Play (Call Log Monitor, one with a red icon) selected all the log (with the check boxes) and delete the log. On the Phone log it appears a message saying "Call log empty", tried to make a call and the call appeared on the log."
This definitely worked out! Thanks!
Respected Sir,
I have Sony experia L. I like to play games so i install many games from playstore as well as some apps also.
But all are saved in Internal Storage. I want to save it in Storage card. so can u pleas help me out for same.
Waiting for your positive reply.
Thanking you,
You have to install them on internal storage and move them in settings-apps to your internal SD.
Thanks Nebel, it was so easy
You made my day mate
Thanks
I have fixed it, see my video. Hope it works for you guys too :smileysmileythumbsup:
