I have files on my computer, backed up from Sony Xperia S, I do not have this phone anymore, but I need to get important contacts out of this .dbk file. How can I do this?
You will have a .dbk file aka your backup file from PCC - Now you need to be able to change the extension ie: .dbk to .rar or .zip, To do this go to your control panel and look for folder options then open the tab View, Part way down you need to untick hide known extension types then apply - Now the .dbk extension should be visable then a simple rename will fix it - Then as above open the folder and txt document
hi johannski
i tried your solution but i am facing a problem.
when the restore.tar is created
i go through Desktop\restore\apps\com.sonyericsson.android.contactsimport\_manifest
please help
dude you're the best. this solution was so quick and helpful. keep it up
many thanks to you.. that saved all my contacts
+kudo
I copied both the files on desktop ..when i click on run tar file it opens Nokia Pc Suite....any solution ?
كيف يمكن فتح ملفات dbk
hello i have tried every way i have found on this fomrum to extrack my contacts and none seem to work i have done it a couple of times as i kep thinking i was making a mistake but im not can anybody help?
Have you tried this with your backup file
Hey Guys,
So I followed all the procedure but when I click on the .JAR file, my Nokia PC companion starts.
I'm Running Win7 x64
Any ideas?
Thanks
thank you so much man
