My xperia x10 mini won't turn on!
Not applicable
180 REPLIES 180
Not applicable
errm hi but i don't know where are the batteries located on the x10 mini.
gwhispererz
Champion
Oh, I have forgotten! Then just press and hold MENU (middle hard key) together with ON/OFF key, see if phone vibrates and starts up.
If that does not work, plug phone to charger and try the above method again.
Not applicable
Which above method?
gwhispererz
Champion
My fault ....  Should have made it clearer :smileyhappy:.
Plug phone to charger, press and hold MENU together with ON/OFF key till phone vibrates and starts up.
Not applicable
Yup. I have done that just now but the phone is still stuck at the sony ericsson screen and keeps rebooting.
gwhispererz
Champion
Only left with Software Repair .... Here's the download link to SE Update Service, http://dl-www.sonyericsson.com/cws/download/1/110/61/1317636927/Update_Service_Setup-2.11.10.7.exe. Use this to reload software to phone, no requirement to switch on phone for this process.
Please note that phone data will be erased completely, SD Card not affected. Unfortunately, you are not able to backup phone data.
Good luck.
Not applicable
I tried that before. It told me to slide down the status bar and tap on mount but i can't even turn on the phone how to mount it?
gwhispererz
Champion
Ok, please follow these instructions ....
- Download SE Update Service to your PC/Laptop.
- Launch SE Update Service and follow on-screen instructions.
DO NOT switch on phone, just connect to PC/Laptop via USB when prompted.
Not applicable
Thanks buddy it is working now. You are a great friend
gwhispererz
Champion
Great! Smiling_Face_with_open_mouth_&_closed_Eyes
