my phone has stopped working.
There was no issue with charge,and everything was fine but suddenly it has stopped working.
I have tried various things-- reinserted the battery,again charged the phone,but it is not opening..:(
Please,suggest me what to do? and what is the issue?
Connect the phone to a wall charger > press and hold power & volume up for 10 seconds > let it charge for 2-3 hours
You could also take a look at the following link to see if you find any tips:
http://support.sonymobile.com/global-en/xperiat2ultra/faq/I-cannot-power-on-my-device/
Thanks, it worked..:)
Glad to hear that. :smileysmileythumbsup:
What did you do please help me
