Sony Ericsson Xperia Arc (LT15i) keeps on restarting itself (reboot loop)
JChris
Hi, greetings!
can anyone help me? I've been having this continous and annoying reboot loop problem since yesterday in my Xperia Arc. It started when the phone started to lagg a bit then i tried removing the battery from the case, tried turning it on after a few minutes then this reboot loop started to occur. Since then it hasn't made a single successful boot. Tried connecting it to a PC to try and solving it using a PC companion but the app can't recognize the device due to consistent reboot looping. I tried removing the SD card and/or the SIM as it might cause the problem, I aslo tried inserting a small bit of paper as everyone suggests online inside the battery case, still no luck. .any ideas?
P.S.
I tried browsing for some ideas for repair in these forums but the processes kinda confuses me. I just need a clean and easy repair ASAP. Thanks guys!
50 REPLIES 50
Uliwooly
@jospex
what exactly is the issue, because unlocking the bootloader it is NOT the same as unlocking the screen NOR unlocking a phone from a carrier network NOR giving root access.
