Sony Xperia SP keeps restarting
Raptor3624
I updated my phone to 12.1.A.0.266 a few weeks ago through wifi when Sony released it officially. And now my phone keeps restarting.It doesn't even reach the home screen. Factory reset(under the back panel) and any hard or soft reset doesn't work.
It all started after I updated the phone to the new firmware. The new UI was slow and laggy. Sometimes when I used to pick up the phone speaker used to be switched on.
From a few days, the volume on the screen just showed a horizontal bar and not the actual volume UI.
3-4 days ago Chrome crashed and 2 days ago Google search and Google now crashed. I installed Amazon kindle app for Android last night but that too crashed in the morning.
And from afternoon, the phone itself crashed.
How do I get my phone back to life?
36 REPLIES 36
rohit-garodi
@RAM
Hi can you please tell me what exactly the local guy did??
Caz I have same problem
Please reply
RAM19820831
Hi Rohit,
He said that there may be around 550-600 pieces of same model i.e. xperia sp with same problem.
Actually there was a hardware problem.
Some circuit was corrupted and this problem arises due to network problems.. As per him.
Pls don't go to Sony Care... Bcoz they will simply tooks money and doing nothing..
No solution with Sony guys, instead changing motherboard.
U try with some good local technician.
Thx
Ram Bariya
rohit-garodi
Hi RAM
Thanks, will try for it
buboy
When i updated the video app, my phone began to restart most of the time especially when my 3g is on. So i decided to uninstall the updates but still same thing happened. What should i do cause i cant use my phone when i unplug the charger.
The phone heats up that you cant handle it any longer while the 3g is on. I found out that my phone's temperature was 40°c.
Please fix and give us latest software updates. It would be a big help. Thank you.
Ashil
I was on coustum rom when i tride to flash stock rom with flashtool system.sin error occured i tried many times but helpless, so i reflashed coustum rom now i am facing restarting problem.. When ever i tried playing videos ,games phone goes off...complitilyblack then it restart... Some time it hapeens on any apps or in any window... Or in boot screen when ever i connect otg devices its suddenly reboot. But when i connect a charger i will not find this problem.i am able to keep my phone alive only by conneting with a charger source Slightly_frowning_Face ..... And wrong battery values are shown...
I tried use an otg on recovery mode no problems found and battery values are correct while phone is powerd off.....pls helm me  with  a solution.
Tags (1)
pratik847211
How can I format and repair my phone if phone is only getting switch off till it connected in pc that to again n again
nkango
my sony xperia sp is switching on and off continously. in other words it keeps restarting
