Sony Xperia T not turning on
nictorina
Hi
My 6 month old sony xperia T was fine today about 2 hours ago (sufficient battery too). When I checked it 5 mins later it wouldn't turn on and hasn't since.
If I press the power button a little white light flashes on the LED bit for a split second, then nothing.
Any ideas?
Thanks
23 REPLIES 23
Emma2014
Hiya
I was wondering if any1 has tips on how to get my sony xperia t to switch back on.The red light comes on if u hold the button down but phone is dead:( wont switch on at all.
Thanks, Emma
profile.country.RO.title
_alexdon_
Charge it for 2 hours,repair with SUS:
http://www.sonymobile.com/gb/tools/update-service/
alexdon
whitty79
mate you should just not interfere you seem to know nothing!!!!!!!!!!!!
whitty79
good man vryman am trying that no !
QueenieT74
Worked exactly as described. Thank you! This has happened before and I foolishly took it into the Vodafone store where they said they couldn't fix it and sent it away for 4 days! Why can't they train their staff to do this?! Bah!
sachidanandabg
THank you its working
RZ
i tried to take a screenshot today with power button and volume down. it didnt work. i then tried to press the power button to check if its working, it locks and unlocks the screen but power off option not appearing, neither i can tk screen shot.. wats wrong ? wat shud i do ?
Danalini
Thank you so much Slightly_smiling_Face
Although the link diverted me to a download, it only bl00dy worked. My phone is now on and working & I am very happy.
thank you
nbe
I tried all of this and its still not turning on. just some vibrations and red led flashing sometimes.... any help?
amup112
when i put the phone to charge in the wall charger the red light is blinking continuously .... what should i do????
