It's been a week already. I am not able to recognize my xperia p in PC, cannnot charge without shutting down the phone, unable to restore/update via any modes(volume up/down).
Whenever I connect the Sony charger, it says 'USB devices disabled error, consuming more power than expected'. It won't charge. When I shut down the phone, it starts charging and charging icon is displayed. If I switch on the phone while charging, sometimes it stops charging, and sometimes it continues charging!
I tried all possible ways, SUS, PC Companion, emma tool. Phone just doesnt get recognized PC.
I live in India, been to sony ericsson service centers before, they are not so reliable. they fix some problem and introduce some other.
So, I am hoping for DIY solution. I think, somehow if I am able to reset the software through PC through PC companion or SUS it'll be okay. But I am not able to do that since phone is not getting recognized by PC in any mode.
I tried reset factory settings in my phone, but no help. Problem still remains.
Couple of times I tried draining down the battery completely, and then charging but still no luck.
Please advise
Try to enable usb debugging mode in developer options,connect after.Reply with what happens.
Thanks for reply. I enabled USB debigging in developer option and reconnected. But still no luck. Device is not getting recognized
Reinstall PCC,connect the phone so the drivers are reinstalled.What windows are you using?
That could be something bad.Still,reply after you reinstall PCC.
I reinstalled PCC, but still phone is not getting detected.
If you say your phone is not detected by any computer,you could try using another usb cable.If that does not fix your problem,take the phone to a sony center,for a quick look.Maybe it is hardware fault.
I do not know,take the phone to a repair center so they can tell you.
