- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Xperia ion hard bricked
I need help with my xperia ion lt28h..
After installing a .zip (Smooth ion) through CWM Recovery, my phone restarted n booted up normally to the lock screen. After i unlocked the screen, it went blank so I pressed the power button and the normal power off button (and some others) appears, so i power off the phone and it went to a boot loop.
I tried pressing the Volume up + power button and connecting it to flashtool by pressing the volume down button and inserting the usbto flash a new firmware but nothing appeared on flashtool
I tried the Volume up + power button again and again and still nothing.. I then pressed Volume up + power button again but longer and received 2 or 3 vibrations (i can't remember) and now the phone is just Dead. No Screen,No LED light, nothing :'(
I tried charging it for 2+ hours and tried connecting it to my pc to see if it does anything but apparently nothing happens.
Somebody please help me :'( This is my only phone and I have no other
Xperia ion LT28h
Firmware: 6.0.F.0.72 (LT28i 's Firmware)
Bootloader: Unlocked
And Rooted with Busybox installed
I know this is not the exact place to ask for help, but i'm really desperate
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Since bootloader is unlocked, you can only use one of these to flash
Sony flashtool
http://talk.sonymobile.com/message/447378#447378
Flashtool. ( you already tried )
Before using any of the software above, force shutdown your phone
Press and hold the power button + Volume Up button for
10 Seconds > ( 3 Vibrations ) Force shutdown
Now do not try to switch it on. Connect your mobile only when you're asked to.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Nabeel,
Thanks for the reply. My phone is currently dead (no screen, no led even while charging) and nothing i do seems to do any effect.my pc cant even recognize it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Another user had a similar experience as yours. It took more than 24 for the LED to show up when connected to charger. Unfortunately you can't do anything at the moment but to put it to charging for a long time to see how it goes.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
This happened to me before.
Use this thread to recover your phone.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
After charging for like 5+ hours my phone has a red led but it goes off after a few seconds and appear again after that.. What should I do now?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Tried that but it seems to have no effect
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
That red blinking shows that battery is low.
Well i checked about smooth ion.
http://forum.xda-developers.com/showthread.php?t=1969634
I guess you didn't de-odex your firmware before flashing it. if it's true, then this is the only reason your phone got bricked.
Keep it connected to charger until it really starts charging
report everything here after that
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
yeap, i did not know how to deodex my rom and thought that it was not important, i guess i'm wrong
The LED is currently a solid red one since 2 hours ago.. what should i do now?
I then tried pressing the power button to see if if it can boot up, but nothing happened so i just left it as it is; charging.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
That's a great sign.
Your mobile has started charging now, it's charging very slowly.
Now wait for the led to to become green ( it may take very long ). Once it turns green, we would be in a position to flash a firmware using flashtool.
So do that and post the results.
EDIT : Don't try switching it on.
