Hello there
My gf has a Sony Bravia. she lives in a block of flats and has her freeview tv connected to the wall by coaxial. A channel was asking for a rescan to work so I did that but can't find any channels.
I did it selecting Cable, it didn't find a thing.
I tried again with Antenna and it ran for hours but the progress bar for scanning didn't move.
This area is best with Crysta Palace; I looked at Manual tuning and it said signal strength was strong for Channel 22 and 23... what am I doing wrong?
Thanks
Saurabh
Hi
I think it might be worth 'blanking' the channels in this instance and retuning again.
Note: Antenna is when you get your Freeview signal via an aerial (The Yanks call it Antenna). Cable is when your get it via Sky or Virgin.
Hi
thank you! I'll give that a go tonight... as long as she lets me through the door
still wouldn't scan, but your 'blanking' comment resonated so I reset to factory settings and then it found all the channels
Thanks for your help
Saurabh
