Can anyone tell me which battery should be used with this laptop.?
Model VPCF11M1E
On the bottom Model PCG-81212M
The battery which never functioned well: VGP-BPS 21 came with the laptop.
On internet different types are recommended.
Thanks for your help!
Message was edited by: jagojago
Hi jagojago,
Either the VGP-BPS21A or VGP-BPL21 will be suitable. I would advise against a battery not supplied by Sony as we have had numerous reports of problems with these batteries.
http://www.sony.co.uk/group/1237478320951
Rich
That link is not delivering as expected - type your model number in the 'Find Accessories' box to give the exact battery match.
Message was edited by: rich912
Hi jagojago,
Rich
Hi Rich,
Thanks for your advice.
I will order one.
Hopefully it will not malfunction.
Jago
Hi jagojago,
You may possibly find the same battery cheaper by searching 'genuine Sony VGP-BPS21A ' - make sure that you confirm with the supplier that they guarantee it is genuine...
Here is one result.
http://www.kingbattery.co.uk/product_info.php?products_id=1047
Rich
