The accelerometer of my x performance stops after some days so auto-rotate and other stuff does not work anymore until I reboot...
What really disappoints is my Sony Lifelog is recording inaccurate step logging as a result 😞
I am suffering the same problem as everyone else here.
Phone details:
F8131
6.0.1
35.0.A.1.275
I'm reluctant to try any of the fixes posted as the success seems intermittent.
Sony, are you able to quantify "shortly"? Are you talking about a few days, weeks or months?
UPDATE:
I did the recomendations that I posted before, 5 hours ago and still working well.
And I read the notice in several sites, that today Sony says the patch that fix the problem is in the way.
I'm going to tell you guys any update.
Did the procedure of deleting the Google account from the phone and then "reactivating" it.
So far 12 hours with the accelerometer working flawlessly! Before that max 20mins after restart before it crapped out. Restart doesn't seem to be a good intermittent solution at all. Try the account procedure instead 🙂
