Sony Xperia X - headphones not supported
Diana2110
Hello,
My headphones stopped working all of a sudden and the message that i get is headphones not supported.  I tried using another pair,  sony ones and the same message appears.
I have also installed Smart connect but that did not help at all.
Some advice would be great. Thank you!
2 REPLIES 2
Uliwooly
@Diana2110
What if you test your phone in >>> safe mode
Diana2110
Hello,
Just tried and it still shows the same kind of message.  Any other ideas?
Thank you!
