Hi. Only have the phone for a few months to find, maybe 4 times, that when I put it to charge over night and I turn it off, I wake up with my phone on and the green light on, even when the cable has been unplugged. Not so long I had the problem that it kept crashing so my phone has been restarted, rebooted maybe at least 3 times (bare in mind that it's less than 6 months old this phone) which now I dong have that problem but I've got this one.
Any suggestions?
@BrolasBrolas wrote:A new update just arrived. I hope this update should solve the problem.
Nope. Tested it already.
Thanks for the answer. I just download the update and i haven't checked it yet.
What's region is everyone's firmware from.btw? I'm on a US Xperia x. Curious of this is just one region or something.
I am on a Greek Xperia X.
I'm UK and same problem but x compact
Same problem
Hi Everyone,
You might experience that the device turns on by itself, when it is connected to a changer and the battery is fully charged. We are aware of the behavior and it will be corrected in the next software release.
However, please note that software updates are released at different times depending on the operator, market, region or country. Therefore, I am unable to provide you with an exact date for when a specific update will be available for your device. In addition, network operators and specific markets may choose not to use the updates for specific models.
God bless Sony! Lol!
Yessss finally!
Updated this morning phone still turns on while charging 🙁
