X Compact turn on while charging
Alessio_841
Hi Community,
Yesterday I receveid in Italy the October patch update.
After installed them I turned off my X Compact and plugged it to charge during the night. After some minutes, the device turned on it automatically. This strange behaviour repeated twice until I unplugged it to not disturb my night.
Any Sony's stuff could help me about? Is it only a random issue due to the newst update?
I hope in an answer.
Thanks
47 REPLIES 47
SimoRocco81
It doesn't work.....X Compact still turn on while charging!!!!
ConteOlaff1
I confirm that I also have the same problem. Unchanged even with the latest update with two repairs, after the upgraded and after the update.
Let's wait...
Confermo che anche io ho lo stesso problema. Invariato neanche con l'ultimo aggiornamento ne con due riparazioni, dopo l'aggiornamento incriminato e dopo quest'ultimo.
Aspettiamo...
@ConteOlaff
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Jman2
Mine has just done the most recent software update. Turned phone off and put it charging and still exactly the same problem.
ChrisKrix
Latest update just now, still same problem.
reikar
.244 doesn't have the fix yet, so stop reposting same thing all over again. They said it will be fixed in next release.
ChrisKrix
When will the release be released!! Urgently needed.
aeades-peacock
Yearh same here been like this since the October update and it's still residing in the November update.
SimoRocco81
incredible....
EdoBin1
Hello
The most crazy thing is that if you set the alarm and then put Phone off it is not Switching on for the alarm.. This feature is not present in Android... How  this software version can make on your phone without buttons?? .. Would be intersting enable alarm in off mode... Waiting for the fix.. Maybe a xmas gift
EdoBin
Simoubuntu
I've just updated my X Compact to the latest version (december 2017 patch, build .252) and...
The problem is solved!
I woke up this mmm morning and the phone was shut off and in charge. Great!
