Hi @julianblack
I am planing to return my Sony KD-55X8005C 55-Inch 4K and take the LG 55UF860V, could you please confirm wheather LG would be able to passthrough DTS 5.1 via optical output because this is lacking in all sony TV's, as i have no choice to use HDMI in my Logitech Z906 speakers.
I see many sony TV's dont have this option to passthrough DTS or DTS HD MA. I checked Dolby 5.1 works perfect decode in KODI.
Also does LG have KODI ? and would it play all 4k content smoothly (i mostly download .mkv and .m2ts files from internet and a fan of 5.1 surrond system)
What player LG uses to play any HD videos from external HDD ?
Thank you
@webvamsi666 don't forget the main thing in a television: the image! LG Tv's (not the OLED ones) use IPS panels that have big problems in showing good blacks. Just check it before making a wrong decision
Hi to all,
first time on here.
My KDL43755CBU arrived yesterday and it defaults to having the subtitles on.
I'm watching BBC1 on satellite and sts are on.
I turn them off, I then change channel and the sts are on that channel.
I go back to BBC1 for example and they are back on again.
I called Sony, told me do a factory reset and there's no difference.
Also it doesn't recognize my films on my HDD.
I saw other posts with that problem already.
I have seen in the past there is great support on this thread.
Any help greatly appreciated.
Hello everybody!
I just bought a KDL-50W808C and i'm dealing with an unsual problem
I have digital television from UPC Romania (LIberty Global) with digital smart card CI+
I have two channels that are 720p/50hz and the immage is still but the audio is ok and subtitles also.
The rest of the tv channels are 576 or 1080i but 25Hz and working perfectly.
When i change the picture to game mode on the 720p/50Hz channels immage appears but it's very abrupt (jerky).
I presume it has something to do with the picture mode (different settings- i tried every setting on or off but nothing happens).
Thank you,
Alex
Hi @Frady1, we have the same set as you do and we also but only very occasionally have an issue with the subtitles do not turn off at first instance, however normally it will turn off after a couple of attempts? As for the video files not playing, we use an app called es file explorer, this seems to find and play the content on our hdd.
The trouble with getting a free one is you can't send it back for a refund 😞
But yes, they are not distaff-friendly, and my wife is very happy with our new Samsung in the lounge, and the Sony relegated to the study.
Have to say though, that when it was in the lounge, briefly, it worked perfectly with a Sony BluRay player, both with it upscaling and letting the TV upscale (the Sony default when it sees a Sony TV), a DigitalStream PVR, and a Roku 3, plugged into my Yamaha DSP-2500 soundbar, and when feeding back sound from broadcast TV over ARC.
These do seem to be things that only work for some people some of the time, though 😞
Thanks for the reply
mk1.golf.1983.
I can turn them off alright but as I said each channel change they are back on.
Another thing I notice is after about 10 seconds on a new channel the screen goes black for about 3 seconds and it's fine after that.
I take it that is what people have been calling 'black screen'.
I did have a good look on this thread before I purchased.
I wanted a satellite built-in and from that point the Sony was my best bet.
Not good with apps but I'll try your suggestion and thank you very much.
@Frady1 wrote:.
I'm not so sure about that logic, both Samsung and Panasonic TVs have far better twin DVB-S and DVB-T tuners built in, my Sammy even gives me the option to select general or FreeSat (with EPG) tuning.
Interesting. At the beginning of November, danielbeyzade created a standard email (page 241 of this thread if anyone wants to go back and see the full contents) to be sent to the European CEO of Sony to see if it would help resolve the situation - this was specifically in response to the announcement that the youview update would preclude using the satillite or HDD functionality.
Along with some others I emailed the CEO and got a standard 'Thanks for contacting Sony support' email and a case number. This afternoon (2 months after the original email) I've just had an update which said,
"In regards to your query, please reply back to this email with you contact phone number, so we can discuss this issue further." Has anyone else from the original emailers had this and spoken to Sony? I would follow it up and see what they have to say, but I no longer have the TV (having taken it back to PCWorld on the grounds it had been misadvertised) it would be a fairly short conversation.
I hadn't seen the stansard email suggested but I emailed the CEO a few weeks ago and got a case number in response.
Nothing since though.
