I have files on my computer, backed up from Sony Xperia S, I do not have this phone anymore, but I need to get important contacts out of this .dbk file. How can I do this?
HI Johannski
Thanks a lot for ur sugeestion.it worked for me.I really appreciate ur help
I find "Xperia Go" android 4.1.2 backup contacts in Applications\com.sonyericsson.android.socialphonebook folder, after fullbackupdata restoreData.jar unzip and open full_backup_vcard.vcf with excel
I did everything you said, but I have a problem. When I open the .tar file and go into the folder, all I can find is _manifest. Any idea what should I do?
1. Extract Xperia backup “.dbk” file.
2. Try folders "Applications\com.sonyericsson." and find the fullbackupdata file
a) Applications\com.sonyericsson.android.socialphonebook
b) Applications\com.sonyericsson.android.contactsimport
c) Applications\com.sonyericsson.localcontacts
d) other folder "Applications\com.sonyericsson."
3. Download restoreData.jar: http://ge.tt/64TJmne/v/0?c
4. Put “restoreData.jar“ in folder where is the "fullbackupdata" file
5. Double click the „restoreData.jar“, you will see a new file "restore.tar" extract it
6. Then navigate to restore.tar folder
a) restore.tar\apps\com.sonyericsson.android.contactsimport\f
b) restore\apps\com.sonyericsson.android.socialphonebook\f
c) other folder "restore\apps\com.sonyericsson.android."
(if only find „_manifest“ file you find the wrong „fullbackupdata“ file, try another folders Applications\com.sonyericsson……. „fullbackupdata“ file)
7. If find in the “restore.tar“ folder „full_backup_vcard.vcf“ file open it with excel.
Hi Guys
Please advise what Java version i should be using as i cannot run the jar file
It gives me the following error:
"Could not find the main class: org.nick.abe.Main. Program will exit now"
I have tried to reinstall Java same error
Running win 7 64bit
Try new version "Java Runtime Environment 1.7.0.25 (64-bit)" from http://www.filehippo.com/download_jre_64/
Hey there,
I followed the steps from 1 - 8 correctly but dint understand the 10th step, as there no file named 'restore.tar' that is showed up even though my fullbackupdata file is on the desktop and hence i cant do the 12th and the 13th step.
Kindly help me for the same.
Thanks
I coukdn't get any .tar file.
restoredata.jar is opening with winzip and and showing its contents(org,Meta-inf)
hey i got it man...nice
kudoz
